Could you help me?
Discussion in 'The Projects Forum' started by nousatya, Aug 12, 2013.
  1. nousatya
    Aug 11, 2013
    how can we convert 220v AC to 15v and -15v in DC.
  2. WBahn
    Mar 31, 2012
    18,085
    4,917
    With a bipolar power supply.
  3. Ramussons
    May 3, 2013
    561
    92
    To put it simply, you need a Transformer to step down 220V AC to 15 V AC. You will need Rectifiers to convert the AC to DC and reduce the ripple using Capacitors. You may also need Voltage Regulators.
    If you can tell us more - Purpose, Required Current, How steady the Voltage needs to be, etc; more advice can be given.
    Ramesh
    nousatya likes this.
  4. nousatya
    Aug 11, 2013
    no matter about current. the main purpose is to get 15v and -15v in one curcuit.
  5. kubeek
    Sep 20, 2005
    4,687
    805
    Well, good luck then.
  6. Ramussons
    May 3, 2013
    561
    92
    Here you are.
    Ramesh
      File size:
      20.5 KB
      21
  7. KMoffett
    Dec 19, 2007
    2,584
    234
    That circuit will give you +21V/-21V under no load, and will drop to +15v/-15V only under some undetermined full load.
    Ken
  8. #12
    Nov 30, 2010
    16,665
    7,310
    True. Better to use a center tapped 24V transformer for an unregulated job like this.
    Use the center tapped 30 volt if you are going to add regulator chips.
  9. WBahn
    Mar 31, 2012
    18,085
    4,917
    If you want to stay real cheap, then use something like this:
    You would want a 220VAC:12VAC transformer.
    This (or the full-wave version above with a 24V centertapped) will give you about 17V under no load but that will drop as you load it.
    Just saying you want ±15VAC with no current level and no other information to go on makes doing anything more that something real rough difficult.
