Could use help on Diff Amp calculation
Discussion in 'Homework Help' started by laguna92651, Mar 22, 2010.
  1. laguna92651
    Thread Starter Active Member
    Mar 29, 2008
    101
    I posted this earlier with no response, I could really use some direction on this.
    How do I calculate the max peak to peak output swing and the max input voltage that can be applied without any distortion.
    20>=Ad<=30 (single ended output)
    Rid>=20k
    ±10v
    I'm not sure what I need to calculate and what assumptions to make to calculate.
  2. Jony130
    Feb 17, 2009
    3,993
    1,116
    For single ended output
    Au=Rc/( 2*(Re+re)) = 2.4KΩ/ 2*(28Ω+10.4Ω)=2.4KΩ/76.8Ω=31[V/V]
    And the voltage output swing for negative voltage is cut-off of a Q3.
    And for positive swing cut-off if a Q4.
    max input voltage = ( max peak to peak output swing)/Au
  3. laguna92651
    Mar 29, 2008
    101
    Thanks for the reply,what is the re=10.4Ω, where did that come from? Is Au a the max output peak to peak or the gain? Thanks
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    re is the dynamic emitter resistance dependent upon the DC emitter current value and device temperature - plus some constants.
    re is typically calculated from the relationship 26/Ie(mA)Ω
  5. laguna92651
    Mar 29, 2008
    101
    How is this the max peak to peak output?
    This looks like a gain, so it is relative? I assume the max output is before distortion occurs, so it is an absolute number?
  6. Jony130
    Feb 17, 2009
    3,993
    1,116
    To calculate max negative swing remove Q3 from the circuit and calculate the output voltage.
    For max positive voltage remove Q4 and again calculate the output voltage.
    And Au is a voltage gain.
  7. t_n_k
    Mar 6, 2009
    5,448
    783
    I'd be interested to see how the re=10.4Ω value was determined. I'm not sure how one could easily predict the current source value (& subsequently re) from an analysis of the circuit - without reference to some device parameters.
  8. Jony130
    Feb 17, 2009
    3,993
    1,116
    The output current of a current mirror is given:
    Io=\frac{Vt}{R2}*In\frac{Ic2}{Io}
    So for R2=12.4Ω ; Vt=26mV; and IR3=(20V-0.7V)/320Ω=60.3mA
    And from datasheet we can read the "exact" value of VBE for Ic=60mA.
    And β=200.
    http://www.iele.polsl.pl/elenota/ON_Semiconductor/p2n2222a-d.pdf
    Vbe≈0.73V and finally IR3=60.21mA so Ic2≈β/(β+2)*IR3=59.61mA.
    So know to solve and find Io we must use iteration.
    So I start the first iteration with assume Io=50mA
    26mV/12.4Ω=2.096mA
    Io = 2.096mA*In(59.61mA/50mA) = 368.613uA (1)
    Io = 2.096*In(59.61mA/368.613uA) = 10.6638mA (2)
    Io = 2.096*In(59.61mA/10.6638mA) = 3.6084mA (3)
    Io = 2.096*In(59.61mA/ 3.6084mA) = 5.8804mA (4)
    Io = 2.096*In(59.61mA/5.8804mA) = 4.8565mA (5)
    Io = 2.096*In(59.61mA/4.8565mA) = 5.2576mA (6)
    Io = 2.096*In(59.61mA/5.2576mA) = 5.0912mA (7)
    Io = 2.096*In(59.61mA/5.0912mA) = 5.1586mA (8)
    Io = 2.096*In(59.61mA/ 5.1586mA) = 5.1311mA (9)
    Io = 2.096*In(59.61mA/5.1311mA) = 5.1423mA (10)
    So I end calculation here with final Io ≈ 5.1mA
    So
    re=26mV/2.55mA
    10.1Ω ( previously i calculate re for 2.5mA)
    And spice results are Ic2=59.74mA and Io=5.91mA .
    And I skip the fact that current morrow are very poor design.
  9. t_n_k
    Mar 6, 2009
    5,448
    783
    Thanks Jony130,
    I'd not seen that done before. Much appreciated for your effort.
    I wonder if the original 'question' entertained the idea that this degree of deduction was required on the part of the student.
    Cheers,
    t_n_k
