It would a great pleasure for if any body explain me working of attached circuit .
Of course using a MOSFET in place of the BJT will eliminate that source of error (if that error is important to the constant-current accuracy requirement).Because the transistor base current also goes through the emitter resistor, there is an error term equal to 1 / the transistor current gain.
Thank you so much.Both circuits are what is called a transconductance amplifier, where the output current is directly proportional to the input voltage.
Iout = Vin / R9 or R16
ak
How the op amp works?Thank you so much.
Is LED in always ON state.
How opamp works.
by Jake Hertz
by Aaron Carman
by Duane Benson
