Cortex M3 LSL instruction
Discussion in 'Embedded Systems and Microcontrollers' started by Nayani, Jun 5, 2014.
  1. Nayani
    Feb 15, 2013
    Hello all,
    I am trying to use cortex m3 assembly language and found that the instructions lsl and lsr are not shifting the data as understood. I am getting a half word into a register and shifting the register by using lsl and storing the shifted data back. From the description of the instruction, if I shift left data say by 3, then the result should have the three LSBs reset (000) with the other bits shifted towards msb. This is not happening. Some times I see LSB set to 1 some times the data shifts properly. Can some one clarify please? Thank you.
  2. Potato Pudding
    Jun 11, 2010
    684
    92
    Rotate with Carry.
  3. Nayani
    Feb 15, 2013
    First off, manual says clearly 00s will be entered depending on left or right shift. Byte shift seems to perform properly.
