Correction !!!!
Nice
Joined Jun 13, 2009
19
Hi Guys
How can I have an amplifier with :
1- High gain
2- High input resistance
3- Low output resistance
Is it important to use multistage amplifier ??
mik3
Joined Feb 4, 2008
4,843
Then you have to build a common emitter amplifier with a gain of 40V/V and then fed its output to the input of an emitter follower to achieve low output impedance.
bertus
Joined Apr 5, 2008
22,276
So you need a gain of 40 V/V.
What input resistance is required?
What output resistance is required?
Greetings,
Bertus
Nice
Joined Jun 13, 2009
19
Can you please show me the connection
because I tried this configuration (CE-CC) in the PSpice & the gain is approximately = 1 :(
bertus
Joined Apr 5, 2008
22,276
That could be made with a two stage amplifier.
At the input a mosfet for the high input resistance and gain.
Afther that an emmitter follower for the low output resistance.
Greetings,
Bertus
Nice
Joined Jun 13, 2009
19
Greetings,
Bertus
Also CE will give a high gain & input resistance !!!
Audioguru
Joined Dec 20, 2007
11,248
So simply make a CE transistor with a gain of 40 followed by a CC transistor that has a gain of 1. The CE transistor has a high input impedance and the CC transistor has a low output impedance.
