correct sound card isolation?
Discussion in 'The Projects Forum' started by fawcetteng, Dec 16, 2010.
  1. fawcetteng
    Dec 11, 2010
    10
    a question on the common sound card as a function generator circuit:
    If I use an op amp to boost the output to say +/- 5v, is the op amp also isolating the sound card should I accidentally pull too much current? As in I'll damage the op amp, not the sound card? If not, how should I correctly do that? I'm new at op-amps. I see they can handle 20mA or so on the output. What would give me a bit more capability?
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    FET-/JFET-input opamps provide a very high impedance to input signals; in the tens or hundreds of megohms. You should still isolate the sound card from the opamp using a capacitor, just in case you miswire the opamp.
    A sound card line output has nominally 10k impedance. The headphone output is lower impedance.
    Why don't you post the circuit you're considering?
  3. fawcetteng
    Dec 11, 2010
    10
    here is a schematic, using one channel of the head phone output on the sound card. Where and what size cap. would I use for protection?
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Have a look at the attached schematic and simulation.
    C1 isolates the DC input level from the opamp's input; only the AC signal is coupled through.
    The TL07x and TL08x family of opamps has a common mode range (input range) of Vee+3v (or -V+3v) to Vcc-1.5v (or +V-1.5v), so R1 and R2 bias the input to roughly 1.75v. This also keeps the polarity across the capacitor correct, so you can use a polarized capacitor.
    R3 provides a 10k impedance for the input signal, which matches the impedance of the line-out of the sound card.
    U1a is wired as a voltage follower/buffer; this isolates the input from the output. The output from U1a is basically the same as the input, but with a voltage offset from the R1/R2/R3 divider. C2 keeps the reference voltage stable.
    U1b is wired as an inverting amplifier with variable gain. This allows from a few mV p-p out to +/-5v out. C3 isolates the DC level from the actual output. R6 keeps the average output voltage centered around 0v.
    fawcetteng likes this.
