core gap
Discussion in 'General Electronics Chat' started by TAKYMOUNIR, Sep 29, 2012.
  1. TAKYMOUNIR
    Thread Starter Active Member
    Jun 23, 2008
    351
    what is the effect of the gap(core gap) in transformer on the output so if the gap bigger what will happen if it is smaller what will happen and if no gap what will happen
  2. Duane P Wetick
    Apr 23, 2009
    408
    19
    The simplest explanation is to not allow the core to go into saturation. You can find gap equations from the data based upon the material you are using. Saturating a core means excessive current which means HEAT!
    Cheers, DPW [ Everything has limitations...and I hate limitations.]
    TAKYMOUNIR likes this.
  3. bountyhunter
    Sep 7, 2009
    2,498
    507
    In general, increasing gap of the core will reduce the amount of inductance you get but make the inductance more stable with applied current. It also moves the "saturation point" to a higher value of current.
  4. szhighstar
    Jun 26, 2012
    27
    5
    open air gap on the core, one is for storage energy. other is what core is not saturation at DC current, air gap is relation inductance coefficient, air gap is bigger, inductance coefficient is lower.
