Core 2 Duo Vs Dual Core ???
Discussion in 'Computing and Networks' started by vivekanantha7, Jan 13, 2009.
  1. vivekanantha7
    Dec 1, 2008
    27
    HI Friends,
    Do anyone know the difference of Core 2 Duo and Dual Core? In some article, i read like both are same and Those names represents some Parent and Family names of the Chip designed. Still im in confusion. Please Clarify my doubt...
  2. avenge the rage
    Nov 11, 2008
    a core 2 duo is just too dual cores, like a quad core but its faster than that.
  3. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Core 2 Duo is a brand name for a dual core processor from Intel. Dual Core is an processor architectural type, i.e. a processor with a dual-core arch.
    In summary:
    - Core 2 Duo is Dual Core.
    - Dual Core is not necessarily Core 2 Duo.
    Dave
  4. jj_alukkas
    Distinguished Member
    Jan 8, 2009
    751
    5
    Dual Core is an architectural type as well as a processor name from Intel. It is also known as Pentium D. Both the above processors are 2 different processors and belong to the same dual core family too. So dual core is a processor as well as a family. The only difference between these two is the internal architecture, stepping type and process thread handling methods. pentium D came first followed by Core 2 duo. pentium D had a cheaper alternative at that time, the celeron D. Both were dual cores. Its previous launch was the P4 H.T... It doesn't have a dual core but two virtual cores. it processes like a dual core. I am writing from one now which runs at 3.3GHz... I feel its as fast as a Core 2 Duo and at 3.3, its cool.
  5. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Ah yes, Allendale and Wolfdale were branded as Pentium Dual Core (not Dual Core on its own, presumably to remove ambiguity). They are low-power compliments to the Pentium D brand IIRC.
    Dave
  6. jj_alukkas
    Jan 8, 2009
    751
    5
    Exactly ...
  7. gregdevid
    Member
    Feb 4, 2009
    18
    The L2 cache is the same. The Core 2 Duo is the next step up from the Dual Core that Intel released. They are basically the same technology but the Core 2 Duo does run at faster speeds. The prices of Core 2 Duo are almost always going to be more expensive but if you are looking into buying something new right now, i would recommend buying the Core 2 Duo to prepare for the future.
  8. jobbin
    May 18, 2009
  9. anandcrks
    May 30, 2009
    hi boys
    1]dual core is: 2 core-chips are there and
    2]core2 dual is: 2 core-chips are there ,
    both are same but
    speed is different
    because depend upon "L2 catch" and 'Fbs" those are speeds
  10. happypossum
    May 31, 2009
    that's correct
  11. zimbarak
    Feb 8, 2009
    56
    In many ways Core 2 is the same as Core: The chips are built using the same production process and fit in the same sockets as Core Duo chips. Putting aside Core 2 Extreme (a fancy version of the Core 2 Duo), you won't see many spec changes: Both chips have the same frontside bus speed of 667MHz, but Core 2 Duo is now available at somewhat faster clock speeds (as I write this, 2.67GHz chips are available). The frontside bus communicates between the CPU and RAM (and other components), and it's a notorious performance bottleneck for computers. The Core 2 also has the same L2 cache that the Core has. However, there are architecture changes to the silicon that give the Core 2 more sophisticated processing abilities. Both chips exist in desktop and laptop versions.
