Cordless phone detector.
Discussion in 'Wireless & RF Design' started by nerdegutta, Oct 30, 2011.
  1. nerdegutta
    Thread Starter Moderator
    Dec 15, 2009
    2,568
    806
    Hi.
    Which of these circuits would be best for detecting a cordless phone ringing?
    The phones are Siemens Gigaset, I think... It's at my parents house.
    I only need a circuit to detect the RF signal, the LED bit I hope I can manage to put in myself.
    The volume on the cordless phone is not high enough, so I thought some flashing LEDs or something would draw the attention to the phone.
    Also, I guess it is not recommended to breadboard this type of circuit for testing, due to all the stray capacitance and long legged components...
    I've googled and youtubed a lot, and these circuits gets hit all the time.
  2. radiohead
    May 28, 2009
    474
    31
    On the first circuit, do you have a component list? The IC is probably a 555.
    The second circuit looks simple enough to breadboard, just to see roughly how it will perform.
    The third circuit uses an op amp to amplify a weak signal and feed it to a 555 that drives an audio indicator. If all you require is a visual indication, you can omit the entire 555 circuit (C7 and everything to the right, except for the battery and switch).
    If you want to build a prototype and don't want to breadboard it, you can use the dead bug (air circuit) or Manhattan style of circuit construction.
  3. nerdegutta
    Dec 15, 2009
    2,568
    806
    Yes it's a 555
    Tried it, but it didn't do anything. :(
    I only need visual indication. So this I might try.
    Now why didn't I think of that! :rolleyes:
    But which of them would be best?
  4. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    The circuits you show do not have a real RF detector in them.
    The transistor or IC are supposed to perform the function.
    The circuits on this page do have detection diodes in them:
    http://www.techlib.com/electronics/cellhelp.htm
    Bertus
