Copyright question
Discussion in 'General Electronics Chat' started by webplodder, Apr 1, 2013.
  1. webplodder
    Mar 23, 2010
    15
    I was thinking of using diagrams from the 'All About Circuits' E-books in a free, online teaching project about electronics. I was also thinking about using a simulated voice to, more or less, produce an audible replication of the text. What problems should I be aware of?
    Thank you.
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    On the opening page of the AAC this is given:
    Here is the desciption of the "Design Science Licence":
    http://www.allaboutcircuits.com/l_dsl.html
    Bertus
  3. webplodder
    Mar 23, 2010
    15
    Thanks, bertus, but could you simplify it a bit for me? I do not intend to use the text in the E-books verbatim, just as a guide, although I would need to replicate the illustrations 'as is.'
  4. codeboy2k
    Jun 18, 2012
    7
    I am not a lawyer, but from reading the license it appears to be a type of copyleft, and thus the information in the books freely copyable, in whole or in part, and redistributable, in whole or in part, so long as you attribute the original author on the parts you take and use in your derivative work. Furthermore, your derivative work must also be released under the same license terms, i.e. it must be released under the same Design Science License.
  5. webplodder
    Mar 23, 2010
    15
    Thanks codeboy, but exactly what steps do I have to take, in plain language, when posting images and/or text to other websites from the e-books here?
  6. codeboy2k
    Jun 18, 2012
    7
    Again I am not a lawyer, but it would seem that you must quote the source of your image if you take it and post it on another website (clearly must not be mistaken for your own work) and (2) your entire post to that website then becomes a derivative work that must be released under the Design Science License. It is not clear to me whether or not you must state that license term, or it simply is.
    What this means is that your posting, the text of it, and the included graphics you have taken from this site must be available for anyone else to also use, modify and redistribute under the same Design Science License terms. Your textual work is copyrighted by you, the author, but the license allows others to also re-use your work (which is a derivative work of this site). If someone else does reuse your work, they must attribute it to you, and similarly release it under the Design Science License.
  7. webplodder
    Mar 23, 2010
    15
    Many thanks, codeboy2k, I appreciate your reply, although like you, I'm not entirely clear exactly what I'm expected to do to completely comply with the requirements of the license. You have made things a bit clearer, nevertheless. Thanks again.
  8. shortbus
    Sep 30, 2009
    4,096
    1,692
  9. webplodder
    Mar 23, 2010
    15
