copper perf board island cutting
Discussion in 'General Electronics Chat' started by masa6614, Sep 19, 2009.
  1. masa6614
    Thread Starter Active Member
    Nov 9, 2008
    49
    I'm working on some prototyping, and been using this 1sided copper perf board, like shown ( http://en.wikipedia.org/wiki/File:CopperCladPerfboard_2.png ) .... Now if i wanted to make the bottom mostly a ground plane, i'd need to isolate some of the holes for the rest of the circuitry. Now i seen a tool like this from Vector, a pad cutter, http://www.vectorelect.com/Catpdf/Page 71.pdf , but they seem overly expensive. Now i dont know much about drill bits, but doing some google searching for 'pad cutter', doesn't turn up anything in what i'm looking for. A drill bit would be fine, with that type end, the pilot for a 0.042" hole, and the outer ring 0.125" , would be nice. Any suggestions on the type of tool or other keywords I should be searching for. Even something that would remove the whole pad area of 0.125", but with the pilot as well, would work too. Thanks.
  2. jpanhalt
    Jan 18, 2008
    5,699
    909
    Woodworking stores sell "screw extractors" like this:
    See Rockler: http://www.rockler.com/product.cfm?page=2354&filter=drill
    They are still quite expensive for what you get, and they don't automatically center. I would just make one by filing teeth in a piece of steel tubing -- like SS hypodermic tubing -- and fixing a piece of music wire with epoxy for centering.
    John
  3. rjenkins
    Nov 6, 2005
    1,015
    69
    I just use a bare twist drill bit, around 3.5 or 4mm.
    You can get a specific tool, a 'Spot face cutter' - it's basically a drill bit tip in a plastic handle; eg. here:
    http://www.maplin.co.uk/Module.aspx?ModuleNo=1926
    Either is fine for both breaking tracks at holes and creating clearances on the ground plane.
    To isolate tracks between component holes, I normally use a needle file & notch across the copper. The end of a snapped-off 'junior hacksaw' blade also works quite well for creating even-width isolation cuts.
  4. t06afre
    May 11, 2009
    5,939
    1,222
    I must say that, your board seems to be difficult to work with. I prefer this type. And I use a drill bit 3mm to cut tracks
  5. masa6614
    Nov 9, 2008
    49
    Thanks alot for all your suggestions
  6. flat5
    Nov 13, 2008
    403
    17
    Thought it best to use an 'island cutter' thread even though it's quite old.
    You must use a drill stand but these 'diamond cutter' bits do a fine job of making moats.
    I recommend 6mm, 8mm, 10mm, 12mm. If you only want to try one then 8mm because the pad will be smaller.
    It costs 0.79 Euros! Free shipping. (will take over a week)
    http://www.banggood.com/3mm-125mm-D...Glass-Porcelain-Tool-Drill-Bits-p-918257.html
    It's actually a good site to buy parts & tools. I've spent over 250 Euros so far and am happy.
    Edit: over 800 Euros
    Bernard likes this.
  7. ian field
    Distinguished Member
    Oct 27, 2012
    4,460
    792
    You can buy a spot-face cutter as you describe - most people just use a drill-bit.
    Stripboard isn't cheap, and I don't like wasting holes - so I cut narrow slots between them with a Swan & Morten scalpel.
    This used to be easy when the blades were available from a pharmacy, now they're only from craft shops etc - and brittle. So if you take up my method, keep your fingers out the way while pressing on the blade!
