Coosing a Current Shunt.
Discussion in 'General Electronics Chat' started by R!f@@, Apr 1, 2014.
  1. R!f@@
    Thread Starter AAC Fanatic!
    Apr 2, 2009
    8,785
    771
    The supplies I had in mind can Supply 10 to 12 Amps .
    I like to chose a current shunt. I chose this.
    Will it be suitable or do I need to go for high rating like 20A.
    I never used these before.
    I like to know the what the data actually says.
    I am thinking that if it says 75mV 15A, it will drop a total of 75mV when 15A of current flows through it.
    OR is it 75mV per 1 Amps ?
  2. MaxHeadRoom
    Jul 18, 2013
    10,827
    2,495
    It should have a resistance rating also, if the numbers are correct it would be .005Ω?
    Volt drop at 15amps.
    Max.
    R!f@@ likes this.
  3. odinhg
    Jul 22, 2009
    65
    15
    The downside with buying components from eBay is that they usually don't provide a good datasheet or complete specifications.
    But for all the current shunt resistors I have used in the past, the current rating have been for continuous operation. So a 15A shunt should be enough.
    I'm pretty sure it is 75mV/15A (5mΩ). Also based on previous experience.
    R!f@@ likes this.
  4. alfacliff
    Dec 13, 2013
    2,449
    428
    the 75 mv indicates that it is to be used with a 75mv meter, and voltage drop acorss the shunt is 75mv at 15A. if you use a shunt with .001 Ohm,you would read 15 mv at 15 amps. most of these surplus shunts were not designed with digital meters in mind.
    R!f@@ likes this.
  5. R!f@@
    Apr 2, 2009
    8,785
    771
    Thanks guys.
    I am making my own meter here.
  6. ErnieM
    Apr 24, 2011
    7,434
    1,625
    I've bought a few of these off EBay, different values but similar when I needed a .0025 ohm reference resistance.
    My $3000 Keithley micro ohmmeter says it is spot on. Had to snag it away when a load bank needed a sense resistor and 20A thru the 30A rated device goes on all day.
    They have an excellent Kelvin terminal arrangement. I used similar decades ago that were 10 times the price.
    R!f@@ likes this.
