That relay is designed to mount on a PCB (Printer Circuit Board). When straight the pins should be in multiples of 0.1 inch spacing for a standard board. Unless they are to mm spec. Hows your soldering skills and creativity? Just make sure you get the pin out correct when you wire them.
Ron
Ron
