cooling sys
Discussion in 'The Projects Forum' started by amperahe, Aug 22, 2007.
  1. amperahe
    Aug 11, 2007
    7
    we are doing a project about an outdoor cooling system.. we would like to make situations sensitive.. we would be using misting system for outdoor use.. we are planning to make it automated by making it turn on only when the environment gets hot... and when it is turned on.. a certain timing delay would be used so that the mists is turned on/off during a specific interval of time.. and when the environment is cool again the whole system is turned off.. anyone who could help me?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    This does not sound too different from systems designed to regulate greenhouse temperatures. You might try a bit of googling...
  3. recca02
    Apr 2, 2007
    1,211
    is the temperature range considerable enough?
    thermistors might do the trick if not.
  4. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
  5. wesleycspears
    Nov 6, 2009
    I have patio misters, it actually helps me during summer days when the weather gets hot. And I bought mine from <snip>, I don't know if this is the one you are looking for. But I know, there's a lot of misting systems there you could choose from.
    I guess I would also probably like the one with timer and temperature sensitive. That would be a nice idea.
    Moderator: Commercial link removed - this is also a two year old thread.
