I would like to learn how to calculate the size (inc. thickness) of an aluminum / metal sheet that I will need given an average of a high-power COB LED chip in order to cool it.
Basically, I'm working on a DIY lighting project on an indoor open space.
I will be using a non-brand / eBay / "Alibaba" LED chip (but a "better" one with larger chips on the board).
They do not have exact specs but I believe I can roughly estimate wattage that will be dissipated.
So.... If I know the wattage, how can I get a rough idea of aluminum sheet I will need?
If my constraint is the thickness of aluminum sheet (example 5mm or 0.2 in)..
.. How can I calculate the surface area I should have?
There can and probably will be slight breeze through to a fan passing over it.
Aluminum sheets I can buy likely to have a density of about ~2.7 gr per cm3.
For 5,m thickness I can buy either "6082 T651" or "5083 O" type.
For 3mm thickness I can buy 1050A or 5251 H22 type aluminium.
P.S. I really do not want to skip hunting on eBay or around the neighbourhood to find cheap but nice heat sinks. A sheet would work much better for my project.
Thanks!
Eg., (please correct if I'm deeply wrong):
Chip: 75w (18-22v, 3500 mAh) red LED chip, powered at 20v, 1800 mAh == 36 w
With the advantage of driving at lower current, let's say we get max. %25 efficiency and 27w needs to be taken care of.
Thanks!
