takao21203
- Joined Apr 28, 2012
- 3,702
100W LEDs are tough to cool. With good VGA coolers you can maintain 30W LEDs. For a 100W LED you almost have to use 4, and place in the middle.
Pay me some money, I make you a prototype. I've done it with no more nails, and smaller LEDs, working for some months.
The power supply isnt easy too.
I used for instance a laptop brick, 2x large 20W LEDs in series on 2 VGA coolers, and a 12v/35v booster module hacked to 60 volts. At this voltage you have quite a few volts margin between LEDs turning on, and LEDs current reaching nominal current. Always remained cool, and was quite bright.
Blue LEDs are quite iffy, they overheat and just zap more easily, while the red one's are more tolerant.
Cree LEDs are prone for just one chip failing, fixed by connecting a cluster of single LEDs.
2012 I had quite a lot of this stuff around, but its all gone now, also dont have much space now.
Just the VGA coolers wont do if you use some hundred Watts (I had upto 500).
You need a large fan for convection too, or it all heats up within a few minutes.
And it mainly depends on the substrate (I just had VGA coolers and pentium heatsinks), as well the total area.
Never did any maths, never used expensive materials or complicate circuits or just even screws.
As I say, using 4 good VGA coolers for one 100W LED is a start. You can drive them with 15 volts or more so they spin faster
By all means you should monitor the temperature with small I2C sensors.
Yet a laptop brick is a bit thin for a 100W LED. You have conversion loss for stepping up voltage.
But, you can drive them with less than 100W, recommended anyway for longer life.
So each 100W module as such is not difficult to make (for me), and the compents are cheap and easy to obtain. Just takes the knuckles to use No more Nails on 4 VGA coolers and mount the 100W LED + hack the dc/dc booster (it needs better FET + Diode too, as the original FET will blow at or even below 80 volts, and a better output cap too, but it's all doable.
The good thing is, if you approach 100W, the laptop brick current limit will kick in. If you put 20 laptop bricks in a box they will heat up a lot and will need some kind of simple sinks on them + fans too. Even the cables will heat up if you bundle them.
