Cool tip for desoldering computer boards
Discussion in 'General Electronics Chat' started by Sparky49, Sep 19, 2012.
  1. Sparky49
    Jul 16, 2011
    835
    417
    Hi everyone!
    I learnt a new trick today for removing components from a computer board, or from a pcb with many components.
    If you want to scavenge lots of components from these boards in no time at all, this will help you.
    Rather than using a solder sucker and a soldering iron, use a plumber's blowtorch. Set it to low, and then heat up an area briefly before tapping it on the edge of a table and then all the components just fall out! You can easily remove 10 ics in about 5 seconds!
    Sparky
  2. sceadwian
    Jun 1, 2009
    499
    37
    You have to be very very careful with the application of the flame as there is a fine line between removing a chip and burning it. But the method can work very well. Done it myself.
  3. crutschow
    Mar 14, 2008
    13,473
    3,361
    Shouldn't the be a "Hot Tip"? ;)
    absf likes this.
  4. Sensacell
    Jun 19, 2012
    1,183
    276
    Be sure to hold the fumes in your lungs for a long time, don't let it go to waste!
  5. absf
    Dec 29, 2010
    1,493
    374
  6. BSomer
    Member
    Dec 28, 2011
    433
    106
    You could also use a heat gun. Just heat the opposite side of the parts you wish to remove.
    darn... Allen beat me to it... :)
  7. Gachl
    Sep 10, 2012
    I use my gas soldering gun for desoldering, with the catalyser it can be used as a hot air gun and is adjustable from 200°C to 800°C, perfect for almost all components.
  8. t06afre
    May 11, 2009
    5,939
    1,222
    If you are two about the job. It is often less stress on the chips. One use the heat source and the other pull the chip of the board
