Conveyor Belt
Discussion in 'The Projects Forum' started by micro, Apr 16, 2006.
  1. micro
    Feb 10, 2006
    26
    Actually I need to create a conveyor belt to transfer a glass with water from one place to another place, distance is around 60cm. Is anyone has an idea to create a conveyor belt? Do you have the construction diagram? Thank you first for your kind help.
  2. Gadget
    Distinguished Member
    Jan 10, 2006
    613
    Use a hose.
  3. micro
    Feb 10, 2006
    26
    Thank Gadget. May I know how to construct a conveyor belt with hose? Can you please give me more infromation? Thanks.
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I have no idea what materials you have available but sanding belts for various types of belt sanders might work for you. You would need one that is flexible without being too stiff. Then you need a couple of rollers which you can make from wooden dowels or aluminum bar stock. You need some bearings or supports for the two rollers and a way to tension the belt. Last you need a motor to drive the belt. You need to be careful with the acceleration and the deceleration. I'm assuming that spilling the water is a bad-bad thing.
