Converting Terminating and Repeating decimal into a fraction
Discussion in 'Math' started by Lightfire, Jul 16, 2011.
  1. Lightfire
    Oct 5, 2010
    690
    21
    Our lessons is being even harder.;)Not so, though.;)
    Okay.
    I want to ask if my mathematical solution was correct. I am not going to post the whole mathematical notation. So, just the answer. I hope, I am correct.
    Terminating decimal to a fraction first.
    346.435 = \frac{346435}{1000}
    Repeating decimal to a fraction, for the second.
    0.000^{346}
    Please, the 346 number has a bar line on top, indicating it as a repeating fraction.
    Therefore, my answer is, \frac{346}{999000}
  2. Georacer
    Nov 25, 2009
    5,151
    1,266
    The way to input a bar in Latex is
    Code ( (Unknown Language)):
    1.
    2. 0.000\bar{346}
    and it gives you this:
    0.000\bar{346}
    As far as I can see both your answers are correct.
  3. Lightfire
    Oct 5, 2010
    690
    21
    Okay. Thank you. Georacer, you always answer my math question.!!!:):):)
    3\frac{250}{100}
  4. Lightfire
    Oct 5, 2010
    690
    21
  5. Georacer
    Nov 25, 2009
    5,151
    1,266
    Err, you might want to check your result. It seems that you messed your Latex up and the result is unreadable. Write it in plain one-line equation if you have trouble with Latex.
  6. Lightfire
    Oct 5, 2010
    690
    21
  7. magnet18
    Dec 22, 2010
    1,232
    125
    Looks good from here, good job with the Latex
    Georacer likes this.
