Converting Static Random Hertz To AC Current
Discussion in 'Off-Topic' started by joseph22, May 15, 2015.
Thread Status:
Not open for further replies.
  1. joseph22
    May 15, 2015
    The noise referred to in the title is sometimes referred to as space noise. Not referring to radio static at around 60HZ. As the earth spins and rotates, a constant sound is generated and is detected with underwater sound surveillance equipment. This sound is 6-8HZ. Is it possible to boost the strength of this signal and run it through attenuator banks? Maybe, enough OHM's could be accomplished to provide 12 Volts of useable current.
  2. Kermit2
    Feb 5, 2010
    3,846
    963
    i cannot think of ANY source of electrical noise that one can convert to useable 'current'. converting into voltage is doable, but not a current capable of doing any WORK.
    alfacliff likes this.
  3. Hypatia's Protege
    Distinguished Member
    Mar 1, 2015
    2,844
    1,309
    Please expand on this, IMO it makes no sense...:confused:
    (i.e. Voltage [EMF] is not current and resistance would seem inapplicable in this context)
    Moreover you seem to be confusing AF electromagnetic radiation with sound (i.e. kinetic oscillation)...
    Best regards
    HP
  4. joseph22
    May 15, 2015
    If you can come up with voltage, is it possible to run this voltage through vibrating Mercury to develop current?
  5. kubeek
    Sep 20, 2005
    4,687
    805
    What? :eek: What does mercury have to do with anything? Or did you mean planet Mercury?
  6. Hypatia's Protege
    Mar 1, 2015
    2,844
    1,309
    With sincere respect, I think you need to review basic electrical principles...
    With constructive intent
    HP
    OBW0549 and DerStrom8 like this.
  7. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    Your horrendous misuse of simple terminology suggests you don't have the slightest understanding of basic electrical concepts. I suggest you do some research before pursuing this further. You'll save yourself a lot of time.
    Papabravo and cmartinez like this.
  8. alfacliff
    Dec 13, 2013
    2,449
    428
    vibrating mercury does not generate electricity. and there is no em or audio available (other than lightning, and it dosnt last long enough to generate any usable work) with enough strength to do any usable work, or supply usable power. science fiction isnt always science fact.
  9. joseph22
    May 15, 2015
    Mercury is a good conductor of electricity. When it is vibrated, it produces current. So, if 6-8HZ can be converted to voltage, why not run this voltage through vibrating Mercury to produce a useable current.
  10. Hypatia's Protege
    Mar 1, 2015
    2,844
    1,309
    @joseph22
    Are you, perhaps, thinking of rectification/detection techniques...?
    Best regards
    HP
  11. MikeML
    Oct 2, 2009
    5,451
    1,066
    Joseph, are you a troll?
    OBW0549, Reloadron and DerStrom8 like this.
  12. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    Haha that's hilarious!
  13. Hypatia's Protege
    Mar 1, 2015
    2,844
    1,309
    Potential difference is produced when conductors cut magnetic flux howbeit, by no stretch of logic, is your post descriptive of practical generation technique...
    Best regards
    HP
  14. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    Perhaps you're thinking of piezoelectric elements? Vibrating a conductor of electricity does not generate current.
  15. OBW0549
    Mar 2, 2015
    1,389
    932
    This thread is nuts.
    Hypatia's Protege likes this.
  16. Hypatia's Protege
    Mar 1, 2015
    2,844
    1,309
    @joseph22
    Please be advised that 'voltage' cannot be converted to current per se --- Rather, a current exists wherever a 'voltage' (i.e. potential difference) is imposed across a finite impedance...
    Best regards
    HP
  17. MrChips
    Oct 2, 2009
    12,624
    3,451
    In the interest of maintaining AAC at some respectable standard this thread is now closed.
  18. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    There is no thing like free energy.
    You can convert a voltage to a lower voltage with higher current.
    The output power will always be lower as the input power due to conversion losses.
    Bertus
Thread Status:
