Can anyone suggest a way i can convert voltage from a 9 volt battery into -9 volts,I dont want to switch polarities I just need a fixed circuit i can use.
If you only need a small amount of negative rail, you can use a capacitive charge pump circuit like the 7660 or even make one with a spare timer output on your micro driving a capacitively isolated doubler. If you have a MAX232 serial port level shifter on board, you may be able to steal a bit of V- from it.
