converting Keil assembly file to hex file
Discussion in 'Embedded Systems and Microcontrollers' started by majoritical, May 2, 2008.
  1. majoritical
    Nov 20, 2007
    12
    Hi guys,
    I am using the Keil micro vision to program my 8051 in assembly.
    How do i convert this to a hex file. Its currently saved with a ".s" as the ending.
    Links to possible downloads or sample lines of code (if necessary) for conversion would be much appreciated.
    Thanks.
    Jay...
  2. Caveman
    Apr 15, 2008
    471
    Read the Keil documentation. You basically need to assemble it.
