I would like to start off by saying that there is an old thread that is similar to this one: http://forum.allaboutcircuits.com/t...-regulator-to-constant-current-source.107534/
However, the rules state that I shouldn't just hijack someone else's thread and should instead reference it in a thread of my own.
So here we are.
What I am attempting to do is convert a high current switching buck power supply to be a constant current source for driving a high powered diode. (Don't worry, I have the proper eye protection.)
In the older thread, the stated solution was to manipulate the FB pin of the IC using a calibrated resistor in-line with the load and an op amp to generate the desired voltage signal at the desired current. My question is whether this would be possible with my setup, which uses the attached schematic and has a "Sense" pin. The datasheet pdf for the controller is also attached.
For reference, my operating values are 12V IN, 2.2V, 30A OUT.
Thank you,
Obli
So here we are.
Thank you,
Obli
