Hi I was wondering if anyone would have some advice for the following problem:
I have 4 PWM signals that I want to convert to analog voltage signals.
I realise I can use a simple LP filter to change the PWM signal into a voltage,
the only problem is that the Peak to Peak of the 4 PWM signals is slightly different (but ideally should be the same).
However, the duty cycle of each PWM is very accurate so I would like to find a way to convert the duty cycle of each PWM into a 0.7 to 5V signal.
Could I use a transistor as a switch (or somesort of electronic switch), to get consistent p-p PWM signals, then just use a LP filter?
Any suggestions would be appreciated.
