converting AC to DC using 3 terminal transformer
Discussion in 'The Projects Forum' started by KMK, Dec 25, 2010.
  1. KMK
    Thread Starter Active Member
    Feb 11, 2010
    68
    I have a transformer that convert 240 VAC to a 9-0-9 output.. I have built a bridge rectifire.. which works perfectly well with a normal 2 terminal connection.. however i donot know how to connect this in the 3 terminal transformer.. also if possible, i would like to convert it to a supply which can provide +ve & -ve voltages.. ( either 18 V or +-9 V )
  2. whatsthatsmell
    Oct 9, 2009
    102
  3. KMK
    Feb 11, 2010
    68
    thanks for that link whatsthatsmell.. but if i need two 9V supplies, then i will have to use 2 bridge rectifires, is that right ?
  4. Kermit2
    Feb 5, 2010
    3,858
    968
  5. KMK
    Feb 11, 2010
    68
    well.. thanks for the verification kermit2
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    Here's another way to draw the same thing:
    A bit easier to visualize how to use a single bridge rectifier to get dual polarity output.
  7. KMK
    Feb 11, 2010
    68
    thanks Sgt Wookie.. & the 2 capacitors are place parallel to the resistance.. to remove the kinks ?
  8. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    Yes, but the caps are just shown for placement. They should be quite a bit larger, depends on your load and how much ripple voltage you can tolerate.
    With 50Hz in, 10,000uF with a 1A load will result in 1v ripple.
  9. KMK
    Feb 11, 2010
    68
    ok.. thanks.. but what if i plan ot use this to supply an IC.. ltes say like the 555 and a 4017.. will they work satisfactorily with this 1v ripple.. & how calculate the ripple voltage & the required capacitance ..lets say for 60 Hz
  10. Kermit2
    Feb 5, 2010
    3,858
    968
    s long as the circuit doesn't try to pull more current than the power supply can give, the voltage fluctuation should not be very bothersome.
    Yet again, it will ultimately depend on what application you put the circuit to. If small variations in timing or voltage would affect the operation, then the ripple should be further filtered out(read - a regulator should be used)
  11. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    A simplified formula for ripple is:
    Ripple_Voltage ~= Output_Current/(Ripple_Frequency * C_in_Farads)
    The ripple frequency in this type of rectifier is double the input frequency.
    The formula doesn't account for many things, such as transformer impedance, capacitor ESR, etc. However, it's still useful to get in the proverbial ballpark.
  12. gootee
    Apr 24, 2007
    447
    50
    This page is good, for unregulated power supply design:
    http://www.zen22142.zen.co.uk/Design/dcpsu.htm
    If adding a regulator, keep in mind that you need to keep the regulator's input voltage higher than its output voltage by at least its "dropout voltage" spec. Otherwise the output gets rather nasty.
