The pulse is between 1ms and 2ms long every 20ms (a standard PWM pulse for servos). Is there an easy way to read that pulse and convert it to an analog voltage from 0 to 5 volts? Thanks.
That is the feature to which I was referring.Thanks. I am using an AVR microcontroller... I was not aware of the input capture interrupt. Before I was using a bad "while pin is high count time" kind of thing. I will look into input capture. Thanks for the help!
by Jake Hertz
by Jeff Child
by Duane Benson
by Aaron Carman
