I am rebuilding a wireless sensor assembly which uses a lithium battery (3.6v 2.4Ah), I will be placing this inside a part which needs to be sealed. The part feeds off of 110vac, but there are virtually no 110vac to 3.6vdc power adapters small enough to fit. I calculated that the sensor uses about 5-10mA at most.
Are there any solutions which would fit in a space about 2"x2"x1"?
Appreciate the help!
