I am attempting to build an automatic plant watering device. I am using a preexisting circuit built around four #4093 Quad 2 input Schmitt NAND Gate IC's. This circuit generates a 2kHz pulse for 0.1 sec. that is intended to light an LED. I am replacing the LED with a solenoid that will drive a valve connected to a reservoir of water. I need to turn turn the 2kHz pulse into a single pulse so that the solenoid can be actuated.
