Converting 5V to 3.5 for I2C -> Nunchuck
Discussion in 'The Projects Forum' started by SteveDord, Dec 29, 2010.
  1. SteveDord
    Dec 29, 2010
    Hello - I am trying to connect a Nunchuck I2C connector to a Devantech USB-I2C interface. The Nunchuck is calling for 3.5V but the I2C source Voltage is 5V. Can I use a resistor in parallel to lower the voltage from 5->3.5??
    This is a software guy forced to tinker with hardware and it has been 20years since I have used Ohms law :)
    SteveD
  2. marshallf3
    Jul 26, 2010
    2,358
    201
    Wouldn't want to do that in parallel, but two simple rectifiers in series will pull around 1.2V off of the 5V.
  3. shteii01
    Feb 19, 2010
    3,500
    511
    You want voltage divider, that is resistors in series.
