converting 50mv dc to ac
Discussion in 'The Projects Forum' started by Sankalpsood, Jan 29, 2016.
  1. Sankalpsood
    Jan 19, 2016
    9
    i need a circuit to convert 50 mv dc to ac.
  2. crutschow
    Mar 14, 2008
    13,477
    3,362
    And what will the AC output be used for?
  3. Kermit2
    Feb 5, 2010
    3,847
    963
    Use a dual pole relay, solid state preferably.
    Drive it at 120 hz using a double reversed wiring, so you get a positive going wave 60 times a second followed by a negative going one. A 555 timer is recommended to drive the relay. Feed the relay created AC to a transformer if you want something closer to a sine wave instead of the block shaped squarewaves.
    A more detailed description of your needs AND the problem it would solve will enable us to better help.
    Sometimes the solution you want is not the best approach to solving your own problem.
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    He wants to drive a fan with a TEC device and cannot seem to get enough power to drive a low voltage fan.
  5. KMoffett
    Dec 19, 2007
    2,584
    234
  6. Papabravo
    Feb 24, 2006
    10,340
    1,850
    As I understand what he is trying to do, he intends to use only a single device to drive the fan. The choice of the device and the fan are not arbitrary, since not all combinations will work. I think he might need some guidance in this regard. He is under the mistaken impression that voltage amplification, via an opamp, is equivalent to power amplification, which it is not.
  7. Sankalpsood
    Jan 19, 2016
    9
    no, i am not at all mistaken about this. I know that power amplification is not at all this easy but first if I am able to amplify voltage, I guess I will be able to amplify current too.
  8. blocco a spirale
    Jun 18, 2008
    1,459
    369
    Guessing doesn't make the impossible possible.
    SLK001 likes this.
  9. Sankalpsood
    Jan 19, 2016
    9
    Who told you that you can be something in this field of innovation. You have such a negative mind. Anything which is impossible is impossible because no one gave the efforts required for the work to be done. Guessing doesn't make I possible but belief does.
  10. Evanguy
    Member
    Dec 21, 2014
    81
    8
    There is a trade off going on. you cant amp up both current and voltage without adding power to some point of the circuit. you can trade current for volts or volts for current. but not add voltage and add current. where does the extra power that wasnt there before come from? thats why you should use watts as measurment. 5w is 5w no matter if its 100v or 100a.
    absf likes this.
  11. blocco a spirale
    Jun 18, 2008
    1,459
    369
    Is that a quote from a Disney movie?
  12. Dodgydave
    Jun 22, 2012
    5,143
    768
  13. Sankalpsood
    Jan 19, 2016
    9
  14. Papabravo
    Feb 24, 2006
    10,340
    1,850
    If wishes were horses the beggars would ride. Basta cosi?
  15. #12
    Nov 30, 2010
    16,665
    7,310
    You aren't the first severely uneducated person to make these claims. You could not possibly know the thousands of man years that have been dedicated to this thing which you call, " no one gave the efforts required for the work to be done." You are insulting brilliant people across several centuries.
  16. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I am no stranger to innovation having started numerous successful enterprises. One of the talents of successful innovators is that they don't waste their time running down roads already traveled, and fields already ploughed. You can rant an rail all you want, but it will result in not a single iota of progress.
    absf likes this.
  17. JWHassler
    Member
    Sep 25, 2013
    204
    34
    generally, you can amplify voltage or current, but not both
  18. kubeek
    Sep 20, 2005
    4,687
    805
    You cannot make more power from less power, wihtout the increase coming from somewhere else. Basic law of the universe known as conservation of energy.
  19. alfacliff
    Dec 13, 2013
    2,449
    428
    It would be much easier and possable to make a sterling engine, an air motor that runs on heat.
