Hi there.
Here's the situation. I have a 36Vdc golf cart and I want to run gadgets on 12Vdc. Pretty basic situation. Of course, I can take 2 of the 6Vdc batteries and make a 12Vdc out of them, which is how I'm setup right now. I could say the reason I want to have a converter is to keep the load on the battery balanced, but with my lamps running rarely, it's not really an issue.
No, the reason I want to make one is that... I want to make one for the fun of making one.
Now, on the LM338 spec sheet, there's a lot of examples and they all works. My problem is that, at "low" the batteries gives bout 28V and when charging, they're being pumped at 45Vdc by the charger.
Now, I would like to keep my output at 12V. How to do that?
There was a schematic using a LM318, but I fried it when I cranked my variable power supply over 35V.
Any idea of how to make a DC-DC converter, at 15Amp min, that would give a steady 12 (or 13.8Vdc) output with the input varying from 30 to 45Vdc??
There's always the solution to "unhook" the converter when recharging, but I would like to go witout it.
Regards,
Pierre.
Regards,
Pierre.
