Oh in that case the battery charger will not be able deliver the current. I did not know they needed so much current.radiator fan normally draw 15 to 20 Amps
Depends on the battery charger.Oh in that case the battery charger will not be able deliver the current. I did not know they needed so much current.
Some fans draw quite a bit more than that - up to 40 amps (see Lincoln).radiator fan normally draw 15 to 20 Amps
and the dual fan setup:FLEXALITE TRIMLINE STRAIGHT BLADE FAN, BLACK -- 14 in. fan diameter, 14-3/ 4 in. x 14-1/ 4 in. x 3-1/2 in. overall dimensions, 10 blades, 1585 cfm, 9.5 amp draw, 2220 fan rpm at 13.5 V DC, 21 degrees fan blade angle; Reversible type;
These were found via: http://www.autopartsdeal.com/Parts_List/electric_cooling_fan/lincoln/town_car/FLEXALITE LOW PROFILE ELECTRIC COOLING FAN, BLACK -- 26-1/4 x 15-1/2 x 2-5/8 in. overall dimensions, 2500 CFM air flow, 14-22 amp draw
So I guess anything is possible. But I think the amount you would pay to convert the 120vAC to 12vDC at those current levels would more than cover the cost of an AC motor.1979-1993 Ford Mustang Flexalite Radiator Fan
FLEXALITE BLACK MAGIC X-TREME FAN, BLACK -- 15 in. fan diameter, 17-1/ 2 in. x 21-1/ 2 in. x 4-3/16 in. overall dimensions, 8 blades, 3300 cfm, 18.0 amp draw; Puller type; With built in control box with adjustable thermostat, A/C relay and manual switch connection; The strongest 15 in. fan available that provides constant cooling regardless of engine RPM
