The motor itself makes a pretty good filter. That's one of the reasons that PWM waveforms can be used so successfully with DC motors.Thanks. Is there any simple (cheap) way to reduce or remove the ripples in the output. Is a filter practical in this case??
3 phase SCR full-wave bridges have been used for decades for DC servo control, you do not need ripple removal with 3ph due to the low percentage ripple level compared to 1ph.Thanks. Is there any simple (cheap) way to reduce or remove the ripples in the output. Is a filter practical in this case??
I think it would be good to use an electrician because that amount of power is incredibly dangerous. You have to go, "Full Safety Practices" because you might not survive even one mistake.Actually I want to convert 3 phase AC (which is about 415V here) and give the output to a dc motor. Is it better to use diodes or thyristors in this case ?
I fully concur -- if you are asking the kinds of questions you are asking, then there is a REAL good probability that you really don't have the level of knowledge and experience to safely work with these kinds of systems unsupervised. So pay the money to get someone that can supervise and educate you about these systems -- the cost is minimal compared to the cost of getting tangled up with this kind of power, even if the only result is damaging some equipment.I think it would be good to use an electrician because that amount of power is incredibly dangerous. You have to go, "Full Safety Practices" because you might not survive even one mistake.
For only rectification; 6 diodes will do fine, you can replace 3 of the diodes with thyristors if you want to control the output.Actually I want to convert 3 phase AC (which is about 415V here) and give the output to a dc motor. Is it better to use diodes or thyristors in this case ?
This is slightly higher voltage but the same effect can be imagined with 415 vs. the 480 3-phase here. I have a screw driver in my maintenance dept that was dropped across some similar power sources - not much left. A small slip of a screw driver, or a poorly tightened lug can cause some major damage in a fraction of a second. By damage, I don't mean the building.I think it would be good to use an electrician because that amount of power is incredibly dangerous. You have to go, "Full Safety Practices" because you might not survive even one mistake.
by Jake Hertz
by Duane Benson
by Aaron Carman
