convertAC/DCwithout diod
Discussion in 'General Electronics Chat' started by fanoudi, Apr 7, 2012.
  1. fanoudi
    Apr 7, 2012
    hi, I convert AC/DC with out Diod work it , for example convert AC/DC with SCR,transistor or ... plese help me
  2. PaulEE
    Member
    Dec 23, 2011
    423
    32
    A BJT has a diode in it...
  3. Kermit2
    Feb 5, 2010
    3,852
    967
    #12 likes this.
  4. Adjuster
    Dec 26, 2010
    2,147
    300
    What are you actually asking for? There are other things than diodes which can rectify under certain circumstances, such as synchronously switched MOSFETS, leaving aside that these many also provide rectification due to parasitic diode action if not correctly driven.
    Historically, rectification was sometimes accomplished mechanically by vibrating or rotating switches, the commutators of brushed Dc generators effectively worked in this way.
    Early battery charging equipment sometimes used electrolytic rectifiers, inefficient and hazardous devices which may not have been referred to as diodes.
    Note however othat the thermionic valve (or vacuum tube) rectifier is in fact the earliest rectifying diode of all, after which semiconductor diodes were named by analogy. Gas filled rectifier tubes may not be called diodes so often, and certainly the polyphase mercury kind are (or were) more complex beasts.
  5. jimkeith
    Oct 26, 2011
    539
    99
    How about a high voltage spark-gap rectifier? --used in old geiger counters.
  6. KMoffett
    Dec 19, 2007
    2,584
    234
    Google doesn't get me anywhere. Got a link?
    Ken
  7. debe
    Sep 21, 2010
    955
    185
    I dont know how it was done, but I wrecked a large 240V ac to 48V dc battery charger that used SCRs as the rectifiers. It put out 48V dc @ about 200Amps. It came out of an old telephone exchange.
  8. jimkeith
    Oct 26, 2011
    539
    99
    Hi Ken, This I recall from reading Popular Electronics in the '50s --well before the days of google, so it is possible that this technology has fallen through the crack.
    How it works--a breaker point inductive discharge generates a specific polarity at the coil output--connecting this point to a capacitor through a spark gap causes a high voltage charge to be stored in the capacitor. I can see that this could be tempermental if the plasma decay is not sufficiently fast when the voltage across the gap is reversed--similar issue to recovery time in microwave duplexer discharge tubes
    Another rectifier technique not mentioned is the use of electrolytic capacitors--yes they do rectify, but have substantial recovered charge--they were used in the early days of radio, but obviously not widely as there is little doubt that their lifetime was severely limited
  9. jimkeith
    Oct 26, 2011
    539
    99
    Hi Daryl, Did this use high (hundreds of hZ) or low frequency magnetics?
