Convert variable DC to 120V 60Hz AC
Discussion in 'The Projects Forum' started by ptpaterson, Aug 24, 2010.
  1. ptpaterson
    Aug 24, 2010
    I have the project that is to create a small scale wind turbine. It must be able to compensate for varying winds and loads to maintain 120V 60Hz AC. I am expecting the DC generator to put out a maximum of a couple hundred Watts.
    What can I do to convert this to a steady AC current at 60HZ? I have not selected a generator so I am not sure what the output voltage will be. Any suggestions for choosing one?
    Would a modified sin wave inverter work? That is be able to handle the varying input?
    Thank you.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You first need to define what your loads' requirements are.
    Things like light bulbs and other purely resistive loads like heaters will work OK from a modified sine wave. Motors won't.
    ptpaterson likes this.
  3. tom66
    May 9, 2009
    2,613
    214
    Also, my laptop (Dell Studio 15) would never charge from an inverter. Apparently this is a problem with some Dell chargers.
    You may be able to get away with a simple 12V automotive inverter. The battery voltage can vary from 11.8V (low) to around 13.8V, and the inverter should be able to handle that. Out of that range, though, is anyone's guess. Most would probably shut off below 11V to protect the battery.
  4. marshallf3
    Jul 26, 2010
    2,358
    201
    Tons of info on this out on the internet lately with the great interest in wind power, on a larger scale though.
    Seems to me it's going to be more efficient (and possibly easier) to have a buffer inbetween as in the turbine charges a smalll equipment/motorcycle battery which powers the inverter.
