Convert PIC code from Assembly language to C/C++
Discussion in 'Embedded Systems and Microcontrollers' started by RG23, Aug 21, 2012.
  1. RG23
    Thread Starter Active Member
    Dec 6, 2010
    301
    I need to convert PIC code from Assembly language to C/C++.
    Please let me know the correct approach
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    The correct approach is:
    1. Understand the assembly language program
    2. Implement the functionality in C .OR.
    3. Implement the functionality in C++
    AFAIK there is no automated way to do this.
  3. BMorse
    Sep 26, 2009
    2,675
    234
    What C/C++ compiler are you using?? What processor/microprocessor was the code written for?
  4. RG23
    Dec 6, 2010
    301
    I am using mikroC PRO for PIC from Mikroelektronika
    PIC18f67J90
    Initially I used MPLAB IDE
    The code works fine there
    Will converting to C also help me to reduce the memory gauge?
    Also if anyone has an example from assembly to c/C++ please let me know
  5. RG23
    Dec 6, 2010
    301
    I have written the code in assembly language so check step1
    I need to know how to implement in C/C++
  6. Markd77
    Sep 7, 2009
    2,803
    594
    Pretty unlikely unless the assembly code is badly written.
  7. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    It is easier to modify C in terms of saving memory space.
    Some algorithm can be replaced with a better one...
    OP should give the source code in question, or at least, parts of it, so members here can give an estimate. It's not totally needed to show the complete source.
  8. Papabravo
    Feb 24, 2006
    10,340
    1,850
    You should start with a reference on C like:
    http://www.amazon.com/Programming-L...qid=1345567973&sr=1-1&keywords=The+C+language
    A bargain at $32 and change
  9. nigelwright7557
    May 10, 2008
    488
    71
    Convert very carefully and possibly one subroutine/function at a time and check it.
    I converted 300,000 lines of PC assembler into Delphi and took that approach.
    I still had one or two bugs but got there in the end.
