Convert PC Power Supply to Bench Supply
Discussion in 'General Electronics Chat' started by Distort10n, Apr 1, 2007.
  1. Distort10n
    Thread Starter Active Member
    Dec 25, 2006
    I decided to do this project to have one for myself. $8 'ATX' supply to use for a bench supply around the house. Not bad.
    The bad news...I am not sure if this thing is an actual ATX power supply. The pin out and wire colors are not the standard that I have read on numerous websites.
    Just to name a few. Red is +5V, Black is ground, Orange is 3.3V so on and so forth.
    But the power supply my buddy gave me is so far off this industry standard and I have no luck finding a pin out. So I had to open the supply. Thankfully, the PCB board lists the voltages next to the wires:
    Red +5V
    Black Ground
    White -18V
    Orange +12V
    Yellow -12V
    Purple -5V
    Grey Power Good
    And there are two brown wires that I have no idea what they are. The PCB shows P/C and F/C on the board connections. Any ideas?
  2. kender
    Jan 17, 2007
    Neat idea!
    Check out my favorite site for pinouts: It's in English, even though it's in the .ru domain. Also, It's peer-reviewed.
  3. Distort10n
    Dec 25, 2006
    After a few short trials and errors, I used a 16 ohm, 10W power resistor between the +5V rail, and P/C. Must be 'power control.' All the rails come up. It looks like the +5V rail that always came up is standby power.
    Works like a charm.
  4. John Luciani
    Apr 3, 2007
    The ATX power supply specifications are at
    There are usually minimum load requirements for some of the outputs
    (typically the high current outputs).
    Some of the newer supplies have a PSON# signal that needs to be held low
    to turn on the supply. PSON# is usually controlled by circuitry on the motherboard.
    Use the +5VSB to power any circuitry you need to have on all the time.
    (* jcl *)
