Convert Matlab to VHDL
Discussion in 'Programmer's Corner' started by Sesshomaru, Aug 9, 2008.
  1. Sesshomaru
    Feb 24, 2008
    Can anyone suggest me a software that converts a code in matlab to vhdl and vice-versa...after posting this thread only i understood i had posted it twice....i dunno how to change the title..sorry for the trouble caused by me...
  2. roddefig
    Apr 29, 2008
    149
    Simulink HDL Coder will convert Simulink models to VHDL or Verilog. There may be some functionality to bring HDL code into Simulink. I do know there is a function in Xilinx System Generator, a similar product, that will simulate HDL code. I don't think there is anything available for m-code. See http://www.mathworks.com/products/slhdlcoder/
  3. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    The only thing I know that provides anything like this functionality reliably is AccelDSP from Xilinx. I would, however, caution against using code-converters in this way as you are likely to get redundant or broke code because of the limitations in the conversion process.
    You may wish to consider the option of converting Matlab to C and C to VHDL as there are several (fairly reliable) converters on the market for this. Again, you are likely to end up with redundant or broken code. Always best to design from scratch.
    Dave
  4. roddefig
    Apr 29, 2008
    149
    I've had good experiences with Xilinx System Generator. It's come a long way since their first release. I wouldn't do my entire design in it, but for the DSP sections it saves me quite a bit of time, especially when it comes to debugging.
  5. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Have you tried using it on your own bespoke M-code, or have you only synthesised the design from Simulink models?
    I might trust its reliability on the latter more than the former because of the pre-defined structure of the Simulink blocks.
    Dave
  6. roddefig
    Apr 29, 2008
    149
    Oh no, it only works from Simulink models, though I think there may be functionality to work from simple M-code. And, you build the model using blocks from their own library.
  7. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Yes, thought as much. I don't use Simulink often, so might not be worth having a look at, is certainly one I will to the bookmarks for future though.
    Dave
