convert from ssquare to traingular wave
Discussion in 'Homework Help' started by ronybhai, Sep 18, 2012.
  1. ronybhai
    Sep 18, 2012
    97
    Your function generator produces sine wave and square wave output waveforms. Explain how you would convert it to produce sine wave, square wave and triangular wave outputs.
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    Think about what you're considering in your other post in the Homework forum. Integration .....??
  3. ronybhai
    Sep 18, 2012
    97
    The integrator can be used to change a square wave input into a triangular output.
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    Apart from getting the integrator design correct, the only other major consideration is that the square wave input should have zero DC offset or zero mean value.
    ronybhai likes this.
