convert C to VHDL
Discussion in 'Embedded Systems and Microcontrollers' started by jun, Dec 20, 2008.
  1. jun
    Dec 4, 2008
    8
    Hi, all.
    I really need help. I've got a problem with converting C files to VHDL files.
    I tried to use the program "System Crafter", but I have no idea how to use it. the free trial is only for 7 days and I only have 1 more days, but even the sample files come with the program don't work for me.
    Is there anyone who has any idea for it? or who has the program to convert files?
    Jun
    p.s. The program above was the only program I found in google that had free-trial. Is there any other program that I can use for free? even once?
  2. Papabravo
    Feb 24, 2006
    10,338
    1,850
    I'm not sure I believe that you can do this conversion. The two languages are designed to solve entirely different problems and are not generally considered to be interchangeable.
  3. jun
    Dec 4, 2008
    8
    however, you can check that they say they can do it with the program on the program's website.
    and also there're many programs doing so, as they say.
    "Impulse accelerate" says also they have the program doing so.
  4. Papabravo
    Feb 24, 2006
    10,338
    1,850
    Claims are one thing. Reality is something else. VHDL has no analog for a large class of C programs.
  5. jun
    Dec 4, 2008
    8
    Thanks..I just figure out the program cannot help my problem..
  6. n9352527
    Oct 14, 2005
    1,198
    Do you realise that those softwares do not actually take standard group of C codes and synthesise them to VHDL? They work with what is known as SystemC language. Of course SystemC is actually C language, however it requires sets of SystemC library to function and compile. The algorithms syntax, however looks like C language.
    Have a look at the SystemC standard site (OSCI) http:\\www.systemc.org.
    There are many synthesiser tools available, for example Synopsys (the original developer), Forte Design, Mentor Graphics, Cadence, etc. Also simulators that take SystemC language as input, such as ModelSim. I have no idea if there are free tools or demo versions of them, but you are welcomed to search for them.
    There are also other information or tutorials available such as http://www.asic-world.com/systemc/
    http://www.doulos.com/knowhow/systemc/tutorial/
  7. jun
    Dec 4, 2008
    8
    Thank you. I will check what you gave me. however, C files I have are not in SystemC language. when I said "they cannot help my problem" I meant it. Thank you though.
