convert AC motor to DC motor
Discussion in 'The Projects Forum' started by nearownkira, Apr 28, 2008.
  1. nearownkira
    Feb 19, 2008
    20
    Is there any way to modifled an AC motor to use DC power supply to operate?
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You would need to build or buy an inverter to take the DC and convert it into an AC voltage @ frequency that was compatible with the motor.
    AC motors do not normally have brushes like DC motors do. AC motors in general are very simple, reliable, efficient, and designed to operate at a fixed speed by being supplied with a fixed frequency AC voltage.
  3. mik3
    Feb 4, 2008
    4,846
    63
    If it is a universal motor you can power it by DC supply as well as AC. Check it.
  4. FCHW
    Member
    Nov 21, 2008
    12
    This might sound like an uneducated question, but what is the main difference between an AC and DC motor?
  5. FCHW
    Member
    Nov 21, 2008
    12
    I saw in one of the other posts that someone wanted touse a bycicle dynamo to charge a battery. So it is safe to assume tht the dynamo is supplying AC an not DC?
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    That should be a generator, and it will output pulsating DC.
