I was wondering if there is any way of converting a Positive voltage of 10v to a negative 10v?
H Thread Starter hawley3 Joined Oct 12, 2011 1 Oct 12, 2011 #1 I was wondering if there is any way of converting a Positive voltage of 10v to a negative 10v?
SgtWookie Joined Jul 17, 2007 22,230 Oct 12, 2011 #2 Yes, there are ways to do that; inductively and using a capacitor charge pump. The capacitor charge pump method is pretty limited as to the amount of current, and you can't quite get to -10v easily. You can get quite a bit more current using an inductor. How much current did you need?
Wendy Joined Mar 24, 2008 23,415 Oct 12, 2011 #3 I've done it using a 555 feeding a voltage doubler. As Wookie suggests, your current specification is critical.
