Convert 5v serial data to 12v
Discussion in 'The Projects Forum' started by chrisall, Jun 13, 2008.
  1. chrisall
    Apr 15, 2008
    I have a device that sends a string of serial data at 300baud to an ECU. This output is standard async 8N1, inverted so that a 1 is 0v and a 0 is +12v. I wish to emulate this device with a PIC, but this outputs TTL voltages. How can I convert the 5v to 12v?
    Note that I'm not trying to convert TTL to RS232 levels, ie MAX232 is not suitable.
    Cheers,
    Chrisall.
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    A single transistor can be used as an inverting level shifter.
  3. m.majid
    May 28, 2008
    39
    Hi
    I recommend the following circuit.
    It works up to 9600 bps,
    An advantage of this circuit is isolating +12 from +5
    It should work, but I didn't test this circuit practically.
    Try it, if not work then tell me to test it practically.
      File size:
      5.5 KB
      256
  4. lightingman
    Apr 19, 2007
    374
    22
    Just use a MAX232.
    Daniel.
  5. hgmjr
    Jan 28, 2005
    9,030
    214
    I would be interested in learning the reason why you have ruled out the MAX232 right off the bat.
    hgmjr
  6. m.majid
    May 28, 2008
    39
    MAX232 converts 0, +5v to +12v, -12v
  7. chrisall
    Apr 15, 2008
    Because MAX232 converts TTL into RS232 ie, 0v / 5v into -12v / +12v. The ECU im working with doesn't use RS232 comms, it requires inverted 8N1 async where a logic '0' is represented by 12v and a '1' by 0v.
    Cheers,
    Chrisall.
  8. chrisall
    Apr 15, 2008
    Hi, that's pretty much the same as what I've tried already, except I used a 4N25 opto-isolator. I did use a lower value pull-up res and ommited the cap though, so that may be causing problems.
    I only need the Tx side btw, all the ECU does externally once it's received the correct code is turn on a lamp!
    Cheers,
    Chrisall.
