Can we convert 24 volt DC to 5 VDC with use of 7805? is it need any capacitor in input?
M Thread Starter morgenstern Joined Feb 28, 2013 8 Apr 10, 2014 #1 Can we convert 24 volt DC to 5 VDC with use of 7805? is it need any capacitor in input?
MaxHeadRoom Joined Jul 18, 2013 28,702 Apr 10, 2014 #2 What current, if reasonably low it can be done with zener, resistor and cap. Max.
Zerotolerance Joined Sep 18, 2011 55 Apr 10, 2014 #3 Yes you can easily. What's your load amp draw though?
bertus Joined Apr 5, 2008 22,278 Apr 10, 2014 #4 Hello, It is possible, but you will loose a lot of power in the regulator. The heat generated in the regulator will be (Vin - Vout) * Iload. In your case almost 80% of the input power will be transferred into heat. Bertus
K KMoffett Joined Dec 19, 2007 2,918 Apr 10, 2014 #5 Maybe an efficient, off-the-shelf 5v switching regulator like:http://www.ebay.com/itm/3-Terminal-5V-1A-Switching-Voltage-Regulator-Power-Supply-/261243604047 Ken
R russ_hensel Joined Jan 11, 2009 825 Apr 10, 2014 #6 Switching is better for this big a drop. A dropping resistor can decrease the heat in a linear regulator, but does not improve the overall efficiency.
MaxHeadRoom Joined Jul 18, 2013 28,702 Apr 10, 2014 #7 If say it was only 50ma this would only need a 1watt resistor together with a zener. Very simple. Max.
