Convert +/-2.5V signal to +/-5V
Discussion in 'Homework Help' started by ajbrinham, Apr 16, 2010.
  1. ajbrinham
    Apr 16, 2010
    I currently trying to convert a +/-2.5V (ac) square wave signal which is running from a transmit data line from a db-37 connector. This signal needs to be larger because the network I'm using required +/-5V signal.
    There is no ground(0V) available, passive components are required, space is a factor and I have no power lines(+5V etc).
    Any ideas?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Is this homework? If not, why are you stuck with these requirements? What originates the signal?
  3. kingdano
    Member
    Apr 14, 2010
    377
    19
    Agree with these questions entirely.
    Posting the problem itself may help.
