Convert 120VAC Motor to 12V DC
Discussion in 'The Projects Forum' started by longfisher, Jul 19, 2009.
  1. longfisher
    May 23, 2009
    Built a manual chumming system:
    (http://www.sportfishermen.com/board/f29/transom-mounted-chum-churn-111406.html) and a buddy suggested inserting a garbage disposal (GD) into the in-feed chute to make the job of creating the chum even simpler.
    Hmmm...
    OK, all the GD's I could find are 120 VAC. Boat uses 12V DC. Can a 120VAC motor be "re-wired" to operate off 12V DC?
    I know, using an inverter from the 12V DC batteries to 120VAC would be the conventional way to do this. But I read posts in another forum that said someone was successful in re-wiring a 120VAC GD motor to run off 12V DC. That would be even simpler.
    Thanks for any input anyone's willing to provide.
    LongFisher
  2. HarveyH42
    Jul 22, 2007
    425
    5
    Never had a garbage disposal, so... Anyway, just because stuff plugs into the wall, doesn't necessarily mean that the guts are all running off 110VAC. Since electricity and water don't mix well, could be a lower voltage motor, even DC. Re-wiring an AC motor, won't say it can't be done, but it would likely be better to find a 12 vdc that fits the task. They are built differently, but there are motors that run off both AC and DC.
    Wonder if you could use one of those chipper/mulch machines for tree limbs and yard crap. Gas powered, little noisy, but darned if you could stuff most anything in there.
  3. Bernard
    Aug 7, 2008
    4,235
    414
    Are you ready for a 100 A draw on 12V system??
  4. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    No
    It would probably be much easier to fab a mount adapter to mount up a dc motor to a garberator body.
