convert 120V to 220V for appliance
Discussion in 'General Electronics Chat' started by apprentice-electrician, Jul 21, 2009.
  1. apprentice-electrician
    Jan 7, 2009
    How can I install a 208V appliance on a 120V dedicated circuit (12-2 BX) ?:confused:
  2. jpanhalt
    Jan 18, 2008
    5,699
    909
    I is the appliance 3 phase or single phase. If it is single phase, get a transformer for that purpose.
    John
  3. apprentice-electrician
    Jan 7, 2009
    it is single phase. but what kind of transformer are we talking about? can you post a link? how big is it and can i locate in a kitchen? does this violate the NEC?
  4. jpanhalt
    Jan 18, 2008
    5,699
    909
    You will need to know the power consumption of your appliance. Search on "step up transformer" in ebay. Generally, the higher the power rating in watts or KVA, the more expensive. I believe Harbor Freight has them too. Not knowing where you are, however, is a bit of a disadvantage for giving more detailed advice. Are you on 60 Hz or 50 Hz?
    Are you absolutely sure the appliance doesn't have a 110/220 volt switch?
    A 1KW 60-Hz transformer will be about 8X6X6 inches or a little larger. They are not huge, but they do weigh a lot, if you have to ship them over a long distance.
    John
  5. apprentice-electrician
    Jan 7, 2009
    jpanhalt,
    thanks for the lead on this.
    i'm in NYC
    208V/1PH 60 Hz
  6. DC_Kid
    Distinguished Member
    Feb 25, 2008
    641
    9
    be sure the 120v circuit can handle the current needed with step-up xformer, etc.
