Conversions of diameters
Discussion in 'General Electronics Chat' started by RodneyB, Mar 8, 2014.
  1. RodneyB
    Thread Starter Active Member
    Apr 28, 2012
    646
    13
    I sincerely hope this is the right forum to ask this question. I am making some PCB's and I have a drill plot chart they are 30th and 40th. I assumed it was imperial and looked for a conversion calculator on line. And failed.
    I need to know how to convert a measurement shown in th to mm
  2. ericgibbs
    Jan 29, 2010
    2,583
    389
    hi R..
    (40thou /1000)* 25.4 =1mm
    E
    RodneyB likes this.
  3. kubeek
    Sep 20, 2005
    4,687
    805
    That acutally is times 25.4 ;)
  4. ericgibbs
    Jan 29, 2010
    2,583
    389
    Thanks for the heads up... a silly typo!:(
    E
    Will correct
  5. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Or;
    thou *0.0254
    works just as well and is only one operation. :)
  6. ericgibbs
    Jan 29, 2010
    2,583
    389
    hi Roman,
    The OP appeared in some doubt what a 'thou' is, ie: 1 thousandth of an inch, so thats why I used the 1000 multiplier in order to reduce the 'thou' to inches, 40th *1000 = 0.04 inch.
    Eric
    THE_RB likes this.
  7. Gdrumm
    Distinguished Member
    Aug 29, 2008
    684
    36
    If your interested, one of the best simple calculators I've found was written by Joshmadison. Its simply titled Convert. I've used it for several years. It's a small program, bug free, and you can make custom tables with it if you like.
    I hope I didn't violate protocol.
    HTH,
    Gary
  8. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
  9. kubeek
    Sep 20, 2005
    4,687
    805
    I use google for most of my conversions, for example type 67 mil in mm and it will give you the answer straight away. And if you use the little search box next to address bar you don't even need to press enter (in firefox at least).
  10. Veracohr
    Jan 3, 2011
    559
    77
    On my computer with Mac OS 10.6.8, dragging my mouse to the lower right corner brings up some maintenance things, but also a simple converter that I often use.
    For more, I use this: http://www.onlineconversion.com/
  11. t06afre
    May 11, 2009
    5,939
    1,222
    Most ECAD system let you switch between units. Like do your board layout in using the units mils. But then switch to the metric system. Then going over your board with the hole size editor. If that is preferable
  12. markdem
    Member
    Jul 31, 2013
    98
    48
    This is why we should all use the metric system! :)
  13. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Agreed! Everyone but cavemen should be using metric.
    Cavemen can still use bushels and furlongs and sheckels while they scribble email on the cave walls. ;)
