conversion
Discussion in 'The Projects Forum' started by divya.rp, Oct 19, 2008.
  1. divya.rp
    Oct 16, 2008
    would like to know wat r the different methods available to convert 220V 50Hz AC to 12V DC, which occupies optimum space.kindly post me the reply as soon as possible.thank you.
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    A PC power supply? Or are you looking for schematics?
  3. mik3
    Feb 4, 2008
    4,846
    63
    One method is to use a transformer with a bridge rectifier and a linear voltage regulator and the other is to use a bridge rectifier and a buck dc-dc converter. For low power requirements the transformer solution is easier to do and the space is almost the same because it is small. However, for high power requirements a dc-dc converter is more compact and more efficient.
  4. divya.rp
    Oct 16, 2008
    I actually need the entire circiut for the conversion of 220V,50Hz AC to 12V DC supply and also to 5V supply.
    thank you.
