Conversion of MOSFET to BJT
Discussion in 'Electronics Resources' started by ggirishs1989, Jul 24, 2013.
  1. ggirishs1989
    Oct 15, 2012
    5
    Hi All,
    This is seem to be a challenge to me.
    Can anyone let me know is there any possibility that i can convert MOSFET to BJT with all their functionality remaining the same.
    PLS do the needful
  2. ggirishs1989
    Oct 15, 2012
    5
    Regarding the conversion of MOSFET to BJT I found in one thread saying by adding a zener diode we can convert the same... But I am not very sure of that solution.
    Pls do help me
  3. ggirishs1989
    Oct 15, 2012
    5
    Will be waiting for th valuable replies.
  4. MrChips
    Oct 2, 2009
    12,635
    3,454
    Can you replace a pig with a cow?
    Can you replace a vacuum tube with a BJT?
    Circuit, circuit, circuit.
    Show your circuit!
  5. wayneh
    Sep 9, 2010
    12,386
    3,244
    Great analogy. Without more detail, most folks would say no. But there will be times when you can. It all depends on the details.
  6. LvW
    Jun 13, 2013
    674
    100
    No - I don`t think so.
    I think, no special considerations - with regard to details - are necessary to give the answer: No.
    Remember: The question was "with all their functionality remaining the same"
    Of course, you can replace a MOSFET in an amplifier circuit with a BJT to do - in principle - the same job: To amplify. However, as far as I understand, this was not the question.
  7. wayneh
    Sep 9, 2010
    12,386
    3,244
    I'm inclined to agree, but without the context of what the OP was really asking about, we can only guess that we understand the question. A cow is not a pig. Both can be roasted over a fire to make a feast.
  8. Ron H
    Apr 14, 2005
    7,050
    657
    There are simple cases, such as driving a relay or an LED, where a BJT or a MOSFET will work equally well.
    The real meaning of "all their functionality" is the key to this question.
